S&H Performance's fuel system wire upgrade has been proven to drop fuel pump duty cycle by 10%+ and will allow you to get more out of your fuel system. A cheap, efficient and easy to install must do mod for anyone looking for more fuel capacity. Our kit runs 10 gauge wire directly from the battery through a relay to the FPDM/FPCM to get the most out of your fuel setup. Comes with everything you need for a complete and clean install.
$39, free shipping to forum members.
Installing a bap on your coyote or 3V? Using this kit to feed your bap will allow it to operate more efficiently, lower amp pull with the increased voltage and drop duty cycle, prolonging the life of the pump and capacity of your fuel system! So don't install a bap without this kit!
Look here for the optional wire harness from the FPDM to the fuel hat for $10 more.
http://www.s197forum.com/forum/showthread.php?p=1351479#post1351479
Have the battery in the trunk or need some custom wiring for your setup? I can build these kits custom for your car for no extra charge.
Kit includes:
-10AWG INLINE HEAT/WATER RESISTANT FUSE HOLDER WITH 30AMP BLADE FUSE
-16FT 10AWG HIGH CURRENT PRIMARY WIRE
-40AMP AUTOMOTIVE RELAY
-1FT 10AWG BLACK GROUND WIRE
-1FT 10AWG HIGH CURRENT PRIMARY WIRE OUTPUT TO FPDM
-1FT 10AWG INPUT WIRE FROM FUEL INERTIA SWITCH
-SELF TAPPING SCREW TO MOUNT RELAY
-HEAT SHRINK TUBING
-ZIPTIES
Kit includes:
-HEAT SHRINK TUBING
-ZIPTIES
