Five Oh Brian
Mustang Guru
This seems like a very tech-savvy crowd here, so thought I would share the progression of my 07 GT automatic coupe after various mods, and how those mods helped at the drag strip....
I never ran my car at the track bone stock, but most 05-09 GT automatic coupes tend to average 13.9's @ 99 mph in the 1/4 mile (give or take a little).
My first mod was 4.10 gears, which required a handheld tuner to correct the speedometer. So, I set that tuner (DiabloSport Predator) to their canned 92 octane tune and ran 13.4's @ 102+ on the factory tires.
The next mod was a bigger stall converter (from Fuddle Racing). It flashed to 3,800 rpm's so the launch was much better, but tough on the stock tires (I really cooked the stock tires before lining up to melt them into submission). Car was running 13.2's @ 103+ when I could get traction. 60' times improved dramatically with the converter (1.8's vs 2.1's with the factory converter).
Drag radials made staging and launching easier and the runs got very consistent: 13.1's @ 103+.
Vortech V2 S-trim supercharger (non-intercooled) took some learning and tuning, and the stall converter now flashes to 4,800 rpm's with the extra power, but conservatively dyno tuned (daily driver) it intially ran 12.6's @ 110+
Swapped spark plugs for colder/copper FRPP 3V0 spark plugs, plus I added an oil seperator and PCV valve to keep oil vapor out of the intake tract. Had more dyno tuning done to adjust shift points & firmness, converter lock-up, etc. Car ran 12.3's @ 111+
Replaced the factory catalytic converters and H-pipe with an SLP X-pipe with high flow cats. Car now runs 12.1's @ 113+.
Always looking for that next mod, and am now very close to the 11's. I don't want to add a roll cage (required when you run 11.49 or quicker), so once I'm in the mid to high 11's, I'm done modding this car. This is a daily driver, so it has to stay streetable. Water-methanol injection is likely my next & final mod, or perhaps a set of SLP long-tube headers to match their X-pipe. Either should get me into the high 11's.
