07 Roush stage 1 whippled
07stage1
2007 Mustang Gt Roush Stage 1. Located in Gonzales LA 70737
The car has 116,xxx miles and is my daily driver, and i have to sell due to my job and the distance i travel everyday. The motor is a fully built 4.6, it was built March of 2011 and the engine has just under 30k miles. The trans is a stock tr3650 w 35k miles w/a spec stage 3 clutch. the car is in great shape and runs great. it made 577hp and 569tq when it was tuned by JMS in MS. Im asking $24,500 obo. The specs are as follows.
2011 roush 20" wheels.
bf goodrich g force tires w 8k miles 255ft 285rear
font bumper repainted last month
2011 style tail lights w/ sequential blinkers
vinyl black out on trunk lid.
interrior is all stock has blue and black leather interrior. the rear seat bottom on the passenger side has a damaged area about 3"x10" it would just need to be re covered or a rear seat delete.
has the shaker 500 radio system
roush short throw shifter
engine:
4.6 3v built by L&m race engines out of PA
custom comp blower cams
comp 26125 valve springs and retainters
manley coated pistons, manley steel rings, manley h beam rods w arp 2000, rod and main bearings, cobra steel crank, arp 4 bolt mainstuds custom 8 bolt windage tray.
motorsports oil pump w/modular billet gears.
heads cleaned amd resurfaced
stainless works long tube headers w/arp locking fasteners cat delete and factory roush mufflers. car gets lots of compliments on the sound
jms fuelmax
twin gt fuel pumps
2.3l whipple blower, jpc monster intake and plentum w 123mm maf and filter twin l&m 72mm throttle body
Steeda 10 rib belt drive 18# pulley combo
new battery and alternator replaced 2 months ago
car has no cel and will pass LA inspection
has aluminum 1pc driveshaft
ds safety loop
rearend:
31 spline mossier axles
ford racing 373 gears
ford racing girdle cover w/pinion support bolts
true trac locker
strange studs and new pinion seal.
lakewood adjustable upper control arm
aftermarket lower control arms w relocation braclets
rear lowering springs steeda 1.25"
steeda sway bar relocation brackets
has strange shocks at all 4 corners
feel free to call text or email anytime for more pics or info 225-262-9336 Chris
07stage1
21k firm
Or if it dosent sell ill part it out to stock and trade it in
