Darkness7
Long story short. I took the car to the track and now I'm hooked. So I'm dropping all the non-essential weight in the car, and these amps and custom enclosure are the first to go. I was 95% finished with the system---as you can see there are no wires routed.
Pioneer GM-4300F
4-channel delivers a grinding 400 watts max (40 watts x 4 or 100 watts x 2 at 4 ohms; 50 watts x 4 at 2 ohms) - plenty of juice to power your high-quality speakers. It’s also got built-in 4-channel crossovers. Speaker level inputs for easy connection to an OEM head unit. Oversized power terminals.
Pioneer GM-5300T
Pioneer GM-5300T Two-Channel Power Amplifier with 760 Watts maximum Power, 10 - 50000 Hz Response Bandwidth, 95 dB Signal-To-Noise Ratio, 250 Watts x 2 Max Output Power / Channel Qty, 125 Watts x 2 Continuous Power / Channel Qty, 2-channel Amplifier Output.
I'll sell the amps for $200 + shipping.
The enclosure is a custom piece that I made myself. (I have experience with fiberglass---there are a few members on here that I've made custom pieces for.) I removed the spare tire and made a mold. It's fiberglass-resin with Bondo to give it a smooth look. It has a textured coating and paint to closely match the factory carpet. It fits perfectly! I will also include the trunk mat-carpet (seeing as how it is cut perfectly to fit), however I will require a swap out of your factory mat. Note: there are a few holes from my N20 bottle that you can slightly see the brackets for in the top of the photos--hardly even noticeable seeing as how they are way up in the trunk.
I will sell both the enclosure and amps for $400 shipped. I'm not exactly sure how much it will cost to ship the enclosure, but if someone wants to meet me locally I will sell for $350 OBO. I am located in the Washington, D.C.--Baltimore area.
I can provide more pics of it out of the car is enough interest is shown. Thanks!
