Stock amp wiring diagram?
Chistopher
How do the stock door subs amp work? There are 4 output wires per amp that are the hot and ground for each subs coil, but how do the 6 output wires work? If I had to guess 4 of then correspond to the 4 inputs and the other 2 are the power and ground to the amp. But then this leaves the question, where is the 5v turn-on wire?
Does anyone know how they work or have a diagram I could see?
