- Joined
- Oct 18, 2011
- Posts
- 310
- Reaction score
- 7
Hello All:
I wanted to pass along our latest install video for the Steeda Bumpsteer Kit located here - Steeda Mustang Bumpsteer Kit
If you have substantially lowered your vehicle chances are you have introduced bump steer. What is bump steer? Bump Steer is changes in toe caused by suspension movement.
Every car has bump steer, however when you lower the vehicle you increase the amount of bump steer that occurs, if this becomes excessive you will begin to notice some unwanted vehicle driving characteristics.
When you turn your steering wheel you are essentially changing the toe of the wheels to turn the vehicle. Excessive bump steer is undesirable because it introduces unwanted steering inputs which means the suspension is steering the car instead of the driver.
If your car is lowered and has tracking issues and less predictable steering behavior, you need a bump steer kit.
Steeda's Bump Steer Kits will allow you to correct your bump steer geometry and can do so without requiring you to drill or modify your vehicle spindle.
In addition, our bump steer kit makes a great service replacement for your worn out, high mileage outer tie rods even if you do not have excessive bump steer issues.
Pick up a bump steer kit today and refresh your outer tie rods and improve your steering.
https://www.youtube.com/watch?v=OcwvdiuVEp8
Best Regards,
TJ
Best Regards,
TJ
