originalsnake
2005 Ford Mustang GT - ONLY 13,xxx MILES!
Satin Silver, Premium Package, Black Leather Interior, Shaker 500
2.3L Whipple H.O. w/ 11psi Pulley
Intercooler
SCT X-Cal 2 Tuner
Custom Tillman Speed Tunes
34lb. Injectors
GT500 Dual Fuel Pumps
HT0 Spark Plugs
IAT Modification
Comp Cams Level 2 Camshafts 127300
Comp Cams Valve Springs
Comp Cams Titanium Retainers
Ford Powdercoated Valve Covers
K&N Breathers
Poly Motor Mounts
Edelbrock Tensioner Brace
Pypes Off-Road H Pipe (stock pipe also)
Flowmaster Axle Back
SPEC 3+ Clutch
SPEC Aluminum Flywheel
McCleod Hydraulic Release Bearing
MGW Short Throw Shifter
Powerhouse Aluminum Driveshaft
FRPP 4.10 Gears
Detroit Tru-Trac
Moser Axles
BMR Upper Control Arm
BMR Lower Control Arms
BMR Control Arm Relocation Brackets
BMR Sway Bar Delete
Hawk Brake Pads
New OEM Rotors
Line Lock
M+H Racemaster Tires
Rear Quarter Window Louvers
This car has been meticulously maintained and cared for. No expense was spared while modifying and upgrading this car and everything has a receipt for proof. The car is in excellent condition and received a professional servicing by Ford less than 500 miles ago. All detailed servicing records and oil changes are documented from the date of delivery. An additional set of rims and tires may still be available at the time of purchase at an extra cost to be settled at that time if interested. (Bogarts & MT's) Please feel free to call with any questions or to schedule a time to see the car. Located in Southwest Suffolk County, NY. I do not have internet access during the daytime so please excuse any lag time in returned messages or PMs. Thank you.
Asking $18,500 OBO.
Intercooler
SCT X-Cal 2 Tuner
34lb. Injectors
HT0 Spark Plugs
IAT Modification
K&N Breathers
Poly Motor Mounts
SPEC 3+ Clutch
FRPP 4.10 Gears
Detroit Tru-Trac
Moser Axles
BMR Sway Bar Delete
Hawk Brake Pads
New OEM Rotors
Line Lock
Asking $18,500 OBO.
