deathwishracer
- Joined
- Feb 8, 2014
- Posts
- 253
- Reaction score
- 2
Got my 408w installed and running in my 2010, got the factory ecu running all the gauges, everything including ac works perfect. 1 issue I have, I forgot to put voltage to the wire in the alternator plug for dash reference. So the voltmeter works, but it occasionally pops up with the check charging system error. I assume because the wire in the 3 wire alternator plug isn't getting direct voltage. Just need to know which wire position in the plug does what
