2010 GT500 1200 miles twin turbo
blacknlte
Odessa, Tx
2010 GT500 Fully loaded with less then 1200 miles All the parts were installed around 800 miles, so parts have less then 500 miles.
$48,000 Firm, no trades Car books for $42k so your getting all the parts for $6K
Car is tuned by HPP is Dallas, tx If buyer is out of the local area it would be good idea to have the car retuned for the area its in to make sure the car runs at its best.
Exterior
Stock with the ground effects painted glossy black
Interior
MGW Shifter
Custom 4 gauge pod in place of overhead light
Autometer: Boost-Fuel press-AEM a/f
Custom Switch panel in center console that hold EBoost2 boost controller-line lock switch-intercooler pump- heat exchanger fan
UPR battery relocation kit in trunk
Suspension
BMR K-member
BMR a arms
BMR radiator support
BMR drive shaft loop
QA1 Front coilover adjustable struts
QA1 Rear double adjustable shocks
QA1 Cast-Camber plates
TRZ Motorsports adjustable upper-lower control arms
TRZ Motorsports adjustable pan hard bar
TRZ Motorsports anit-roll
Dyno tech aluminum drive shaft
Mcleod RXT clutch
Fore billet aluminum rear end cover
Engine
100% stock from supercharger to oil pan
Hellion Hellrasier twin turbo kit
15psi 650hp-760tq
20psi 760hp-840tq
24psi 880hp-950tq
Hellion intercooler
Lethal Performance 3 pump return style fuel system on E85
Bosch 205lb injectors
C&R heat exchanger w/dual fans
C&R radiator
Moroso expanded coolant tank
Moroso expanded heat exchanger tank
Lethal Performance o/r x pipe
Magna flow 3in catback
SCT tuner
WOT box
Lethal Performance line lock
Factory car cover in plastic bag
