2010 GT500 What rear Springs & HID light adjustment when lowering the rear of the car
MrClean
Marc; but I go by MrClean
Friendswood, TX
So I like the stock clearance of the front tires to the front fenders, but the clearance between the rear tires and rear fenders is a little too much.
Therefore, I was to install shorter rear springs (with a higher spring rate) to lowert he back an inch without touching the front. I assume the headlights will point higher as a result of that change. Is there an adjustment that can be made to the headlights to compensate?
Also, does anyone know the rear spring rate of the 2010 GT500? Any suggestions on which rears I should drop in for a maximum 1 inch drop? 3/4" would be optimal.
