stang8psi
can someone with an 2011-2012 look under there hood under the fan shroud cover, where the fan relay plugs in there is another wire/plug on the same batch of harness as the fan connector. Can some one tell me or help me and tell me what the other small plug is plugged into? it is a 3 wire 3 pin plug.. Please help as I have no idea where it goes to after engine was removed and now it's the only plug I cant seem to find the other end to..
