2011 Mustang GT Cobra Jet clone- 15,500 miles
Engine: 5.0L Coyote supercharged -7500 miles
Diamond pistons (9.5-1 comp.), Manley Rods, TSS billet oil pump, ATI damper (20%OD), ARP Head studs, main studs & side bolts and SFI flex plate.
Heads: Trick flow valve springs, Manley Valves and Valve job and port work.
Kooks long tube headers with Kooks off road H pipe and Roush axle back mufflers.
Supercharger: Ford racing 2.3L TVS with High flow inlet elbow and SCJ mono blade throttle body. 2.8” supercharger pulley with custom 8 rib blower drive – 18/20 psi, Larger intercooler and intercooler coolant tank. New winter 2013
Professionally built and assembled by Blue Collar Performance (Westland, Michigan)
Transmission: 6R80 - 6 speed automatic transmission built with HD clutches, billet intermediate shaft and deep pan. Circle D torque convertor (3200 stall) --- 500 miles
Rear Axle: 8.8 with welded tubes, Detroit locker, 3.31 gear with girdle, Moser axles with extended length studs and Strange C-clip eliminator.
Shaftmaster Driveshaft
Chassis and Suspension: 6 pt. chromoly roll bar, Tokico D spec adjustable shocks and struts with cobra jet springs front and rear. CHE lower control arm, upper control arm & mount, pan hard bar, relocation brackets
Lightweight racing battery-new winter 2013
Wheels & Tires: Race star wheels 15x4 front and 15x10 rears with mickey Thompson sr radial front and 295/55/15 ET street rear
Body: Built with all ford racing parts- Fiberglass cowl hood, Hood pins, Faux gas cap, upgraded graphics package, front grille, grille emblem, radiator support, strut mount upgrade, passenger airbag cover and flush mount side window louvers. Agent 47 retro side mirrors and NGR lightweight racing seats.
Extras: Another set of Race star 15x10 with mickey Thompson street tires and 1 pair stock cloth seats.
I did 2011 Hot Rod powertour, Detroit Autorama (2011), Passtime TV show (2012) and 2013 Hot Rod dragweek. Very popular car- gets lots of press, looks and complements
Fun, fast and cool car to drive. Everything is done first class! No short cuts on parts or build
$43,700 or best offer Call Bill 734-762-7246 (home) no text
check it out here
http://www.racingjunk.com/Radical-Street-Cars/182269656/2011-Mustang-GT-Cobra-Jet-1-of-a-kind.html
check it out here
