2011+ Sticking clutch pedal fix
gizmo5
Italian between my legs
My clutch pedal stuck under high RPM shifts. I fixed it.
You can either buy a new line upgrade, buy a new clutch OR do what Im about to show you...
Warning: If you break shit, crash, die, stab yourself in th eye with pliers or in any way become more ugly than you already are after following this DIY guide... I assume no responsibility and you suck. :crazy:
Step 1 - Remove top clutch kill switch assembly for cruise control. Twist it
Step 2 - Remove clip and arm off of the left side of the pedal, clutch hydraulic arm. HOW you ask? Remove the clip on the left side, then push clutch slightly in to remove pressure, you will feel when it will move freely. Pull left and twist arm parallel to the marching surface aka ground.
Step 3 - Pull pedal towards you/seat/back of car. All the way until the spring pops out of its white plastic cup/seat
Step 4 - Remove fuckshitard spring from your life, reassemble everything else, and realize that your pedal assembly is now a GT500 clone with no stupid ass "assist spring" holding the pedal down
See this guy? Fuck this little guy...
Kenaizer
Denver
Haha I wasn't planning on doing this but think I will now just because of this write up.
gizmo5
Let me know how it works for you guys. It made my clutch feel sooo much better, and I went and tried to induce a stuck pedal and couldn't do it. 1-4 shifts all at redline, pedal works as advertised.
mikeyfitz
Resident Fuktard
Houston, TX
Ill probably do it to see what it does. I can't figure out what you guys were talking about though lol
gizmo5
lol, the clutch pedal has a senseless spring that helps push it to the floor board. My hypothesis to this phenomenon is that Ford allowed a vagina to be employed in the pedal assembly design department. Therefore allowing someone to insert a spring assist... Ergo making it a less awesome design than the GT500 unit.
Following the above DIY tutorial will allow you to drive at warp speed and shift like a God...
:thumb2:
Wingspan
I just did this, thanks for the instructions. I haven't had the chance to drive it yet (damn snow) but the pedal feel is much improved.
2012yote
I did this to mine today. Does anyone else have what feels like about a 1/4" free play before you feel pressure?
07TGGT
@user
Mansfield, TX
Yes, and it's normal because you don't have the assist spring always pulling down on the pedal. Nothing to worry about.
iceguyb14
Mustang Fanatic
Fredericksburg, VA
Definitely going to have to try this. I hate my clutch getting sucked to the floor and Ford won't replace shit til they can replicate it which won't happen unless they go around 90mph in my car lol.
Just curious, how stiff is this "assist spring"? Is it really applying a lot of pressure?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
2012yote
The spring made a very noticeable difference. It definitely takes more effort pushing the clutch in now, But feels a lot better IMO.
Sent from my Transformer Pad using Tapatalk
gizmo5
That compression spring is stout! It pushes the pedal quite a bit
gizmo5
Yes, it sits at the top with a smig of free play. A small price to pay for a GT500 setup that feels waaay better. :beer:
2012yote
From what I have read on the internet my month build should have already had the GT500 clutch assembly. And no way was I going to take it to the stealership for the swap so they could dog the shit out of my car as well.
Sent from my DROID RAZR using Tapatalk 2
07TGGT
@user
Mansfield, TX
I highly doubt Ford would put the GT500 units in the GTs to fix a problem they're not really concerned about. Check it and I bet you have the same unit as every other GT
2012yote
Yes I do have the same. I will try and find the information when i get home about the pedal assembly being changed at a certain build date and it mentions what to look for so you would know if you needed the swap. Supposedly they are aware of the sticking issue and are changing them out. I called a local dealer months ago about bringing mine in for it but after reading a story of a dealer damaging a persons car I will try to avoid it at all costs.
07TGGT
@user
Mansfield, TX
Well, it must be build dates after September. I haven't heard anything about the being swapped out though. I'm interested to see where you read that though.
