2014 Mustang Rattle by Driver Door Sill
2014GT500
New Mexico
Hello, I have a 2014 Mustang, and I've had this annoying rattle by the driver side door sill for over a year now. It started out as a clunk whenever my driver side front wheel would hit bumps at low speeds. Whatever was clunking became completely loose and can now move back and forth as I accelerate and brake (video links at the bottom). I can also hear it wobbling around sometimes when I hit bumps. I checked the inside of the door, and the rocker panel, but I could not find any loose hardware in there. I also removed the interior plastic panel where you have the hood latch and found nothing. Also checked on the outside of the car by the door hinges (where you have some foam), moved the foam around but I didn't see anything in there either.
I'm pretty much out of ideas and wanted to know if there are other places I could search. Or could come hardware have become loose in the unibody and there is no chance of getting it out?
Any help is appreciated.
here are the links to videos if the rattle:
Rattle when braking:
Rattle when accelerating:
