https://www.youtube.com/watch?v=yAVQeZBjhUg
Looking for a clean, inexpensive mod that installs in no time?
Then make sure to check out the Raxiom Switchback Turn Signal Conversion Kit!
[IMGLINK]http://i48.photobucket.com/albums/f234/amalexlazarus/YT%20SUBSCRIBE%20BUTTON_zpsqsenrfyc.jpg[/IMGLINK]
[IMGLINK]http://i48.photobucket.com/albums/f234/amalexlazarus/sewitchback%20review_zpsjzdnqucz.jpg[/IMGLINK]
[IMGLINK]http://i48.photobucket.com/albums/f234/amalexlazarus/raxiom%20switch_zps0brhoopa.jpg[/IMGLINK]
[IMGLINK]http://i48.photobucket.com/albums/f234/amalexlazarus/raxiom%20switch2_zpsewo8dex3.jpg[/IMGLINK]
FEATURES:
Improves Lighting and Appearance
Uniform Light Distribution
Dual-Color "Switchback" Bulbs - Change from Cool White to Amber
24-LED; 12 White, 12 Amber, Wedge Base Bulb
Kit Includes 2 LED Turn Signal Bulbs and 2 Side Marker LED Bulbs
Fits All 2015-2016 Mustangs
Here's what you need to know!
- improve the exterior lighting and appearance of your S550 Mustang.
- This conversion kit replaces those weak incandescent stock amber bulbs with super bright dual-color LEDs for a unique custom look.
- The dual-color feature allows you to use the white LEDs for the running/parking lights, but when you activate your turn signals or hazard lights the LEDs change to amber like magic.
What's included?
Complete and includes a pair of two "Switchback" front turn signal bulbs and a pair of two white front side marker bulbs.
Installation?
Installation of the Raxiom Switchback Turn Signal Conversion Kit is 100% plug-and-play. There is no cutting, splicing or resistors required, just replace your factory incandescent bulbs with the ones in the kit. It's that easy!
Notes?
Seeing that Ford redesigned the circuitry of the all new S550 Mustangs, you will not need a resistor to slow the turn signal blinking rate. The exterior turn signals will blink at the same speed as they did before, however the interior dash indicator will blink at a different rate.
Application?
This Raxiom Switchback Turn Signal Conversion Kit is specifically designed for use on the 2015 to 2016 Ford Mustangs, including the V6, EcoBoost, GT and Shelby GT350 models. Recommended for use with clear turn signal housings.
