28" front drag tires?
dragpac
easton,pa
does anyone have a 28" front tire that will fit a 15"by4" rim in a radial? I don't want to run a bias in the front and a radial in the back
Matt D
S197 Pilot
Toronto,Canada
Why so high? run a 26" or 27" Max alot of the Jdm guys run 27" for rollout
Hawgman
THE fucking bad guy
Texas
psfracer runs 28s
psfracer
billy badass
Valencia, CA
I run Moroso 28X4.50X15s up front, but they are bias ply, with the slicks out back. But for a while I ran them with the M&H 325 radials out back and never had a problem. (Maybe because the fronts are so narrow?)
I run a 28 up front because I am stock height, and I did not want a huge rake that would prohibit good weight transfer. The Goodyear slick out back is a 29 tall, so a 26 tall up front would just be terrible (in looks and function).
US-1
Banned
The ShadowLands
It really won't be a problem. Where you run into serious problems with that scenario is if you are running a bias ply tire in the back and a radial tire (usually a stock width tire) in the front.
Just pick one. Moroso, M&H, M/T, Goodyear, etc, etc, etc.
xtweakerx
Get SOME!
Palm Beach, FL
wonder if i should of went 27" in the front on my et fronts to match the 27" ET 's streets in the back? hmmm dang it, instead i went 26" in the front and 27" in the back.
