sportinawoody
was wondering if anyone has done it and what had to be done/swapped and if the power would be worth it.
http://www.s197forum.com/forum/showthread.php?p=217017#post217017
This doesn't discuss the build or what it takes, but will show you the results!
PLStang and Strictly Performance did it too. GT500 engine with KB blower.
PLStang and Strictly Performance did it too. GT500 engine with KB blower. I did notice that no threads on this subject ever mention what harness(es) have to be changed for this swap to work.
Car was inconsistent on the Dyno and had a misfire issue about ever 3rd pull, limiting RPM. Most of it was due to trying to use a 3V Processor (minus VCT & IMRCs and the auto) and running a one cam sensor 4V. The F150 Truck 5.4 3V running the GT500 motor was major pain but the automatic (4R75W) was left in place and few other things were done to make it work that we didn't have time to try. The best Combo is what Mike did... GT 500 Harness , Processor and a Baumantor 4R70w controller work !!!!
Jon L
Wow, really?![]()
...but the GT500 processor and harness was a much easier resolution and I was tired of this cutting into the race season, so went that route.
The GT500 swap was very successful... The only problem is you need a GT500
Veh Ven number to get the parts from ford.. The 07 is much cheaper to do
then the 05/06 because the 07 use the same a/c line the main harness my not
have to be changed... We used just about every part from the GT 500 ...
Fuel lines, coolant lines and hoses, rad, intercooler brackets and mounts,
ic pump, computer, smart junction box, needed changing, we did have to
rewire the box for the smart key.. and you must have the ford computer
software to make all the computers recognize each other..
No.God wouldn't it just be easier to go with a full standalone?
Ta Da!a 4v swap is a simple task. If someone wanted to spend the time and effort a 3v computer can be set up to work. People seldomly want to pay for r&d required to trial and error changes that only "makes things work". The 500 harness and computer are quick and easy to install and easy to tune.
It comes down to a few simple changes, the polarity of the 4v coil packs are opposite of the 3v, simply switching polarity causes misfire codes. The 3v coil packs will not fit under the covers on a 4v (without modification).
The 3v has two cam sensors, the 4v one. This appeared to be a non issue.
sorry guys shoulda been a little clearer in my questioning. i meant 4v heads on my 4.6 motor, not a 4v engine swap. has that been done and if so how beneficial was that as opposed to saylivernois stage2 or 3 heads?
i found a complete gt500 setup for 15000.00 . maybe ill sell my wife, taking offers!
No fucking way. Don't need any of those "wife" things.
