850 hp 2007 gt 25k miles CHEAP !!!
Status
Not open for further replies.
sportinawoody
Piedmont area , N.C.
car has 25k miles, 6k on motor and less on other parts. car makes 850hp on 110 and 790hp on 93 pump
price before the 21st on wednesday is 20,500, after the 21st price is 24,500. moving on to a new project hence the price. these prices are FIRM so dont even ask or show up with less.
there is 25k alone in motor , blower and transmission. dan @ prodyno did all the tuning and can vouch for this car. best form of contact is text or call 336-399-3642.
engine:
blueprinted and all paperwork comes with sale
eagle 4340 crank
eagle rods
arias polydyn coated pistons 8.8:1 compression
hellfire rings
coated main and rod bearings
arp thru out entire engine
tss billet oil pump gears
gt500 pump
canton windage tray
ati damper
stage 3 ported heads
manley race stainless intake valves
manley race inconel valves
bbr stage 2 cams with lockouts
powder coated valve covers matched to car
kooks 1 3/4 long tubes
full 3" exhaust out the rear of car
kennebell 2.8 mammoth currently at 29 lbs boost
department of boost dedicated 10 rib belt drive
saleen extreme heat exchanger
7 gallon water tank in trunk
battery relocated to trunk
fuel:
Full return system
fore triple hat w/ 2 465's and 1 255 walbro pumps
-8 feed line
-6 return line
aeromotive regulator
cpr fuel rails
80lb injectors (needs 1000's)
Transmission:
Tremec Magnum XL T56
scattershield
spec SS trim twin disc clutch
aluminum driveshaft
driveshaft loop
hurst linelock
suspension:
eibach front springs
cobrajet rear springs
lakewood 50/50 rear shocks
bmr radiator support
upr billet lower control arms
lower control arm relocation brackets
upr adjustable upper control arm and mount
upr panhard bar
home built panhard brace
welded axle tubes
3.55 gear
dark star 15x10 with nitto drag radial 275-60-15 on rear 17x4.5 with M&H front runners on front
appearance:
cervini 2 1/2" cowl hood
full gt500 front end conversion
roush rear spoiler
tinted windows
tinted head and taillights.
car really needs a cage and 1000 injectors. other than that car doesnt need anything
car retains cold a/c and everything works properly. factory heated leather seats IUP package.
there are other parts available to buyer that can be added in for extra, will be discussed with the buyer. sure I'm leaving things out but this is the majority. thanks for looking
johnnyv8
South Jersey
If everything checked out, that was a smoking deal for the miles and modds!
Status
