About to order gauges-quick question
SONICBOOST
In it to win it
The gauges that I want are below. I just want to make sure that these are the gauges that I will need for my paxton 2200 system. The wideband says that it does not work with the OEM senders, does anybody know what that means. Will I need to order anything seperate to install these or do they come with everything I will need to install them. Thanks
-Adam
Edit- I want a mechanical boost gauge right.
http://egauges.com/vdo_mult3.asp?Type=ATM_Air_Fuel_Wide&Series=Cobalt&Units=E
http://egauges.com/vdo_ind.asp?Type=Turbo_Boost&Series=Cobalt&PN=ATM-6107
ZmanM3
The Evil One
Jackson, NJ
I believe it means your going to need their sender and your going to need to weld a bun in your exaust for it.
ZmanM3
The Evil One
Jackson, NJ
You may want to consider a fuel pressure gauge as well, I am personally going with a Wideband A/F, Boost/Vac and fuel pressure gauge for my build up.
ILW84U
Edmonton, Alberta
The gauges are fine but you may want to add a fuel pressure gauge also. Wideband O2's do not work with the stock sensors but the gauge comes with the required sensor. You will just need to have a muffler shop add a bung so it can be installed. Other than that, they should come with everything required to install.
SONICBOOST
In it to win it
I should add that i will not be using a fuel pressure gauge and I will not be doing the install...
SONICBOOST
In it to win it
Thanks guys, I didn't really think I needed a fuel pressure gauge because if fuel pressure drops it will throw off the air/fuel ratio which the wideband indicates right, what do you guys think? Also what the heck is a bung...lol do I need to order one or will the instal shop have one, I will be having ST Motorsports do the install...
ZmanM3
The Evil One
Jackson, NJ
I think a fuel pressure gauge is the second most important gauge next to the A/F gauge. Just my opion though.
ILW84U
Edmonton, Alberta
The bung is another inlet into the exhaust system so the wideband O2 sensor can be installed. Think of it as a hole drilled in the exhaust with a nut welded to it so sensor can be screwed in. I know there are pic's out there but I am too damn lazy to find them. ST should have everything they need.
Grabber07'
The flying cheeto
Tulsa, Ok.
Your factory O2 sensors are in bungs. Your just adding an extra bung to screw in the wideband..well thats how I see it anyways.
S197 GT
PINK Casting Director
Nor Cal
Nice choice of gauges.
John and Adam will get you all lined up without a problem. They'll probably have some extra bungs laying around, but if not, any local muffler shop would have them.
I too suggest getting a Fuel PSI gauge when the time is right. It's not as exciting of a gauge as a boost gauge, but it's far important in a supercharged application.
tom281
Warp Rider
To add to the conversation, was wondering if the rear O2 sensors are turned off in the tune, could you just use one of those bungs instead of installing another one?
ZmanM3
The Evil One
Jackson, NJ
Yes you could, but I wounder if having it after the cat or before the cat makes a difference, I bet it does.
tom281
Warp Rider
Probably, but for dudes like me that have the rear sensors turned off because we're running offroad pipes, the cats won't make any difference LOL.
SONICBOOST
In it to win it
I think i'm gonna just go with a boost/fuel gauge. I am only aiming for 430rwhp and I can always get the wideband later on. Seems like the boost and fuel pressure are two of the more closely monitored gauges associated with supercharged stangs
