miketexass788
I know you need one of these to fix your pinion angle, if your lowered alot. But will my car benefit handling-wise with one? I have bmr lca w/brackets, adj. panhard bar, and h & r sport springs.
Depending on what UCA you have they can hurt suspension performance, help suspension performance or hurt and help suspension performance.
An example of help/hurt is the Metco upper. I have one and it has a nice feature which is that it will “twist” in the middle. This is a nice advantage because as the axle articulates the UCA is not resisting the axle movement and allows the axle to articulate freely. The downside is that because the axle can articulate freely the effective wheel rate (suspension resistance measured at the wheel which is made up of spring rate, roll bar, bushing deflection and geometry) is reduced compared to having a UCA that will not articulate.
That being said you don’t want to have your wheel rate comprised of bushing deflection if you can help it. But that is how the car is designed. If you get a UCA that freely articulates with no bushing deflection/resistance your wheel rate will decrease and at 10/10th load you will be short on spring and or swaybar rate.
In a perfect world if you switched to a articulating UCA you would want to increase your rear spring and/or swaybar rate.
So a bmr adj. uca would be good if I planned on getting larger sway bars and better springs?
While on-topic of UCAs, right now I have a CHE adj. with poly bushings.
Do you think it would be beneficial to switch to a spherical/rod end type uca? I would also upgrade the rear end uca bushing mount to steedas spherical bushing.
If the bars and springs you are getting are sold as sets (set of 4 springs, set of 2 bars) it can be assumed that the front and rear are spec’d out to be balanced. If you were to add a UCA with no resistance to twisting to the mix the wheel rate of the rear wheels would decrease and the front and rear of the car would no longer be balanced. It could be possible to get that balance back if one or both of the swaybars are adjustable but it would take testing in a controlled environment to be able tell if the needed range of adjustability is available.
As long as its not the Steeda ultralite springsI wouldn't use BMR lowering springs, not much of an improvement in handling... Go with Steeda or H&R springs
My plan is to use bmr sway bars, k member w/ a arms, adj uca, and their lowering springs, to add to my bmr suspension now. You see any problems?
You can do better on the swaybars... I make bars that are both adjustable, and both hollow... Only BMR's front is either of those things. The rear is solid (heavier) and not adjustable (no ability to tune balance).
Their K-member is more drag oriented and I, in general don't trust aftermarket k's unless they have a robust design--and that one does no. Consider all the lateral load you put in the car ends up in the k-member. We'll brace this and that... then run a k-member that looks like it was built from an Erector Set?
Their lowering springs are pure looks. They are basically stock-ish rates. Much softer than any other lowering springs are, and you need to increase the spring rate to compensate for the lesser travel unless you like riding on your bumpstops and slamming onto them.
As for control arms. I have other preferences, but of the things on your list that's what BMR does best.
