Vapour Trails
The Renaissance Man
I had an alignment performed yesterday and on the advice of a couple of local S197 autocrossers, requested 1/16th of an inch of toe-out on the front wheels.
At the time of the alignment, the printer was not working so the technician showed me the specs on the computer screen. Each side was
-0.16, so I thought it was dead on. Later in the day I realized 1/16th as a decimal is 0.0625 and I really got about 1/6th of an inch of toe-out.
Do you think that this much toe-out would cause premature/uneven tire wear? Or should it be ok? Camber is -1.8 degrees.
