Took a tape measure and measured the distance from the tire to the edge of the wheel well on both sides. It looks like the driver side is pulled a little closer towards the front of the car. As in about 1/8th of an inch.
The car seems to drive pretty straight to me. If it pulls at all maybe just slightly to the left. It is a small enough effect I can't really be sure of it plus roads aren't perfectly level, etc..
Is some variation on this a normal thing?
I just replaced my lowers with double adjustables. Rear end was on stands and it was done one side at a time. Not sure how the axle would've moved but I can't rule it out. Jam nuts were/are tight and had blue loctite put on there too.
Debating on having alignment checked, trying to put stock arms back on to make sure nothing moved, or maybe getting some psychiatric help here. lol
