Yes. The 2010 is a denso, which is a much better design than the Ford 6g on the 2008. The Mitsubishi from the police interceptors fits on naturally aspirated cars with a little tweaking and puts out 215 amps2010 alternator is better and fits no issues on a 2008? interesting.
I believe the b+ has to be turned to fit under the intake manifold, and you would need a larger power wire. 0 gauge would workThat is good info. What kind of tweaking?
That alternator is bad ass man. I've never seen anything anywhere near that size run for so long and put out so many amps. Good stuff.You have to remove plastic power lead, not rotate it. It's not even clockable although I modded mine to do so but even clocking the power lead it it's a no go. I got rid of the power lead altogether and used a plastic spacer/washer and mounted the heavy power wire directly to the stud that the power lead bolts to. It's been working GREAT!
Well after more research o found another guy with exact issue. Turned out to be a bad ground. Going to clean grounds and also as a ground from alternator to battery ground and hopefully problem solved! We will see tomorrow
I learned a long time ago to buy new OEM parts only. Alternators, starters, batteries. It's saved me a lot of headache! Nothing worse than replacing every part in the car when for instance the starter is new - and finding out it's your starter that's bad.
