Another build Round 4...
Boozshey
Tampa
So I got bored and spent some more money on the ride. I will use this thread to update what is going on.
I think this is all for now... If I think of more I will add. Also as soon as I start taking the car apart again I will post pics.
Received
Ordered
Pending
Engine/Drivetrain:
3.6L LC Kenne Bell
Alky Control 5 Nozzle direct injection
95lb Injectors
Fore Fuel Rails
Dynatech Headers 1 7/8" w/ 3" Collectors
Custom 3" Exhaust
Thumper Racing Tensioner
Cooling:
Dad's 7 Gallon trunk mount intercooler tank
Suspension/Chassis:
BMR K-Member (new for the 11+)
BMR Drive Shaft Loops (Front and Rear)
BMR Panhard bar support bar
BMR LCA with rod ends
QA1 Dual Adjustable front coil over struts
QA1 Dual Adjsutable rear shocks
Wheels/Tires:
Weld RTS Black Center 17x4 Fronts
Weld RTS Black Center 15x10 Rears
Track - ET Street Radial Pro 275/60/15
Street -
Front Toyo TR1 275/35/20
Rear Toyo R888 315/30/20
Interior:
SOS Triple Gauge Pod
Dual Aeroforce Gauges
3rd slot will be a mechanical Boost Gauge, Not sure which yet.
Dual Stage Raptor Shift light (Still shopping)
Boozshey
Tampa
None other than more hp with less boost.
The TVS is a great blower and I can't say anything bad about it.
But there is something about lifting the hood to a 3.6 monster blower.
good luck with it, how much boost do you think you'll run and on what fuel?
umm... Bruce... I see no motor in there????
Boozshey
Tampa
For fuel we will run 100% methanol.
Van at Revan Racing things I will be up around 22-23lbs. But I will run a 4" pulley which KB says is a 14lb. I have a 15% lower, but I don't think it's worth 8-9lbs... But I have no idea.
Motor will come I'm sure, just have to let the bank account settle down first.
Methanol? really, uncommon choice, are the 72#s gonna be enough injector?
For a race car it's not uncommon. For a street car, IDK anyone, Ethanol yes.
RetroGT2006
06 S197 Member
Florida
Bruce, that is awesome!!! Can't wait to see it. I need to get back to the family
Boozshey
Tampa
I can buy it at the track 5 minutes from the house in enough volume to sustain.
Ok, good luck with it, guess no road trips.
