ColeStang_GT
- Joined
- Jan 31, 2012
- Posts
- 37
- Reaction score
- 0
Got a new tune from Bama, third revision. Drove like a dream after I uploaded the new tune and cleaned my air filter. Went to the bar for a couple hours, came out and cel came on immediately and started idling rough again.
This time it was p0152(b2s1 Sensor Circuit High Voltage) and p2175(Throttle Actuator Control System – Low Airflow Detected). Switched the tune immediately back to the second revision and still the p0152, along with p0153 again, and p0600(just a burp I guess for the pcm).
Re-cleaned my maf and throttle body last night(maybe a little oil from the air filter clogged up the airflow a tad). So thats all good hopefully.
This morning I went outside and got the multimeter and started shooting the o2 itself. Ohms wise I got 5-6 ohms on the heater element(2 white wires). Voltage wise on the actual circuit with the car running I got about 15-16 when the car as warm on 200mv setting(back and grey wires). Not really sure of the proper readings honestly, havent been able find much online
I just changed this o2 sensor last week. I have no datalog capabilities right now because I don't have a laptop(use a desktop to upload the tunes and update).
So far for the idle problem and running rough problem I have cleaned the air filter, cleaned maf, cleaned throttle body, replaced fuel filter(disgusting to, probablyy gonna run seafoam through it and change it again), replaced b2s1 o2 sensor, checked COP's.
Pacesetter long tubes and o/r h btw. Bama isn't in on Sundays so have to wait till tomorrow to talk to them.
Any ideas?
Any ideas?
