Stock heat range is HT0 correct?^^Good luck , I replaced mine with the Brisks stock heat range..
http://www.toptiergas.com/retailers.htmlWhat do you do when you don't have BP? Shell or Valero are the only two major stations to fill at here.
If you believe in the Top Tier rating system, this is a good reference point.
edit: Just saw that Shell is on their list. I guess you can cross that out..lol
I'm in Florida.What state are you in? Is shell really that bad? I've had no problems so far, but if it will hurt my baby then I will go nowhere near it in the future. I always thought of them as a good brand.
You had a plug burn up? Could you tell me more about the issue you were having?I was going to suggest a coil on plug to try. Also I had a similar issue and it ended up being an injector.
No problem I appreciate you sharing that with me.
