Wow, did not think I'd get this many replies. Appreciate all the knowledge and info you guys, very helpful! I don't plan on touching that screw either! Though I have a BBK twin 62, I'll just be taking it off and cleaning it. Dashpot settings WILL be played with next tune! Also does anyone know any more specifics on dashpot?
Dashpot is one of the parameters involved with the throttle body. A google search will tell you more than I can type.
In short the tune electronically makes adjustments for idle, part throttle, and coming off of the throttle. The adjustments predict airflow requirements for the motor during these conditions.
If the predictions aren't just about perfect the result will be hanging revs, surging, and even motor shutdown during normal driving.
Changing cams, tb, or anything that affects airflow will require adjustments to the predictions for a smooth, stock like driving experience.
IMO being able to tune for aftermarket cams, throttle body, increased displacement, anything that affects airflow during normal driving is what makes or breaks a tuner.
Tuning for safe wot is pretty easy and straight forward. Being able to tune it to drive the beast in normal traffic conditions without issues is what requires skill.
