Has the whole "offset strut" offered by Cortex/Griggs been discussed already? Why doesn't Vorshlag consider that route? I mean if CSamsh has to have spacers to fit 295s and you have to spend money on ARP studs just to use the spacer.... I know Vorshlag would have already considered this (assuming). What was the verdict? Apologies if this has already been discussed and i missed it.
This trick is popular on the modern GTO, because they have ZERO room for wide front tires, but there is no such thing as a "free lunch". There are always downsides to making a geometry change like using "offset struts" to gain inboard wheel room. SAI gets all kinds of f*cked up, among other things. And from what I've read on this very forum, the Cortex set-up has trouble fitting more than a 10.5" wheel up front anyway, so...? Correct me if I'm wrong.
Cmash's car has our Forgestar F14 wheels in 18x11" and he has run 315/35/18 Kumho V710s all the way around, under stock fenders (see picture above). The "problem" is when trying to fit 315/30/18 BFGs, which are fookin HUGE tires. There's only so much room in there.
We build our Forgestar 18x11" front to work with stock geometry + some added negative camber at the top mount (not at the spindle - which eats wheel room) to fit most 295-315mm tires without a spacer, but again - the BFG Rival in 295/35/18 is fookin HUGE and just needs about 2-3mm more room than other 295-315 tires. Cmash's car is shown above on the same wheels with the 295mm Rivals. They are about the same size as the 315/35/18 Kumhos...
While looking up the Kumho specs I noticed a new size: 345/35/18. Well hello there, beautiful...
They also have a new 305/30/18, but its a bit short for the S197 Mustang. When did they start introducing new V710 sizes? Last time I looked there were only about 9 sizes being offered, but now there's 27 sizes. The 315/35/18 is one of the FEW wide R-compounds sizes made in an overall height favorable to the S197 Mustang (which comes with 27" tall tires, stock). The typical 30 series 18" tires always end up looking very short on these big cars.
The hubs are a wear item...they get replaced anyway, so I don't really consider that too much of a problem.
And part of our front hub wear problem has been HEAT, or so we think. When the calipers are sitting at 490°F all the time, and we have visible grease streaks coming off the hubs afterwards, that probably explains a lot. Now that we've added more brake and hub cooling with our 4" ducting, we'll see. Cmash also has upgraded to 4" ducting, too.
...the Rivals have a huge rim protector, hence the reason for the spacers. I don't need them (spacers) when I run 315 A6's or V710's.
Ahh, I thought the spacers weren't needed on your 315s. Yea, the Rival has a huge rim protector section, that makes sense. Shannon runs a spacer with 295 Rivals on 18x10" Forgestars, too.
Wow, that's a welcomed shock! I was told by BFG/Michelin engineers at the launch last year that they were NOT going to make 19" sizes. That's actually a good idea, as too many OEM wheels have gone to 19's (like the upcoming 2015 Mustang GT). And with the 295/35/18 listing backup, we can finally compare some stats...In other news....THEY'RE BACK!!! 285/35/19 is a new size...and looks like all the big 18's are "In Stock" as opposed to "Special Order"
295/35/18 BFG Rival specs:
Section width: 11.9"
Tread width: 11.1"
Recommended wheel width: 10-11.5"
That's right, folks...the BFG "295" tire is nearly TWELVE inches wide. Our 18x11" wheel width recommendation is almost in the middle of the range that BFG recommends, too.
