http://www.turbosmartdirect.com/Product-Categories/Kompact-Series/Kompact-Plumb-Back-34mm.html
Is this a good option use? I like the fact of how quiet it will be for normal driving but still give you a good sound coming off of boost. I would probably recirculate the one end to my custom power pipe i will be making. Thoughts, suggestions and experience with this valve welcomed. It should be the same size as my stock bosch valve so i believe it should work.
