Whoo, that's good to know! Your a good man Jaye!
He's one of my best friends. He'll buy it from me though. He won't let me give it to him. That's just how he is. He's a good sum'bitch.
A good friend of mine just put a Procharger on my buddy's 05 GT with the stock block. The engine had less than 35k miles on it. He took it to a local shop to get it tuned and there was some issues with it running right. They couldn't get it worked out so he took it to a different shop. Turned out to be a bad blow off valve or something to that effect. Swapped it out and they put it on the Dyno and it ran out of fuel at 4500 rpm even though he put a BAP on it. They charged him to put a GT500 fuel system in it. Then they put it on the Dyno and blew his motor up. It there a rod. Prior to this it had shown several codes relating to the 2,3, & 4 cylinders. They said it needed plugs or whatever and put new plugs in. They never did a compression test or even suggested something might be wrong.
Atty agrees. No recourse. It just sucks all the way around.
Your buddy brought them a car that had a bad blowoff valve, a bad BAP, a stock engine, a blower installed by 'a friend', and it came from a shop that couldn't get it tuned right.
So the shop that didn't do any of the fuel system and supercharger installation, and didn't do the initial tuning is now liable for the engine because it blew up on their dyno when they were trying to iron out the issues that they didn't cause in the first place?
Good luck with that one.
Any time you modify you take chances. I can't see how this could be on the shop. For that matter I can't see how your friend could even think of asking them to cover it. It sucks but it's the chance you take.
I realize that and so does he, but there are safe modifications. If they thought there was even a chance his motor wouldn't hold a stock Procharger then they should've told him. He wasn't pushing the limits at all.
Small claims court be best bet. Shops hate going and will usually try and work something out.
really? extortion?
10psi on a procharger is capable of 500rwhp so that's definitely at the limits. Ive signed wavers at some and not at others. If it pops on the dyno it pops its unfortunate. Would be nice if there was an insurance that would cover it. Sounds like there were a lot of issues involved before they got ahold of it themselves. All could have been contributing factors. Plus they literally could have done something stupid by accident an it happen. There is still nothing that can really be done.
