This summer has been brutal with high heat and we’ve had a lot of customers asking how they can help their car stay cool. Here at www.Brenspeed.com we have been installing Afco heat exchangers and Fluidyne Radiators at least 2-3 a week! Here’s the solution...
We all know that high intake temperatures will definitely kill power! To help keep your intake temperatures down, we recommend going with a larger more efficient heat exchanger. We highly recommend the AFCO dual fan heat exchanger. Its nearly twice as tall and twice as thick as the stock unit! The heat exchanger also comes with two 10” fans to help dissipate the heat! Make more power, more consistently with AFCO!
Here's some of the features of the AFCO Pro-Series Heat Exchanger for the Shelby GT500 and S197 Mustang GT: * Fits 2007-2011 Shelby GT500 and Mustang GT's * High efficient double pass design vs. OEM single pass * DUAL 10" Spal Fans * Increased HP do to a dramatic intake temperature drop compared to stock * Quicker cool down times in between runs at the track * Helps prevent heat soak and detonation due to increased intake temps * Simple do-it-yourself bolt on installation * Furnace brazed core (no epoxies) with beautifully tig welded tank construction
CLICK HERE TO SEE MORE INFO AND PRICE ON THE AFCO HEAT EXHCANGER
Haven't been to Brenspeed for a Supercharger yet? You can still take advantage of upgrading your stock radiator to a Fluidyne Radiator to expand your cooling system and keep your engine running more efficient.
Your stock radiator is good for your stock vehicle. However once you start modifying your vehicle to make more power you will also need to upgrade your cooling system to dissipate the heat quickly and efficiently. If you have added a power adder such as a Supercharger it becomes even more critical. Fluidyne has the answer with its all new high-performance radiator. Made specifically for the S197 Mustang this radiator is a direct replacement. 100% Brazed Aluminum Core (No Epoxy Joints)- High Efficiency Air Fins - Polished Aluminum Tanks - Brackets, Hoses and Fittings All Meet OE Fit-Up
We have seen as much as a 20 degree drop in coolant tempatures when combined with a Hypertech colder thermostat. Add the Thermostat and Purple Ice for Ultimate Cooling!!
CLICK HERE TO SEE MORE INFO AND PRICE ON THE FLUIDYNE
WE KNOW THIS WORKS!! WE ALL RUN THIS ON OUR WINNING NMRA TEAM!
LEFT WITH QUESTIONS? CALL US AT 574.594.9559 AND ONE OF OUR TEAM WILL GET THEM ANSWERED! OR E-MAIL [email protected]
NEED A QUOTE ON INSTALLATION? E-MAIL [email protected] !
TOUR OUR INSTALLATION FACILITY BELOW!!!!
