mr. anderson
broke the car on the first of the month on a test and tune, finally tore into it today, here's the snapshot. stock 3.73's, (has the upgraded diff stock ,2011 brembo 3.73 package). I've beefed up the rear end with a che axle brace and the FRPP rearend girdle with bearing supports. I was running MT ET drag 28x10S 15's doing 5k RPM launches. I got more than I thought I would out of the rear end. the only thing I hadn't upgraded was the diff and the transmission. everything else is beefed up in the drive line. 1pc ds, and a McLeod RXT clutch.
here's the results:
notice the weight reduction mod to the pinion gear:
spider gears and carrier:
other side of the carrier and spider gears:
the valley of the dead spider gears:
only good thing about this is the axles are still good.
here's the results:
