351inside
I have my 98 for sale. Its a BAB and has roughly around 73000-75000 miles on it. New motor has less than 100 and every other mod has less than 1500. I need to sell this car because money is tight and i need the money to pay for other things. I wrecked the car about two years ago and never replaced the airbags. i fixed everything else and the car is straight as far as the frame goes. The paint looks a little worn now from sitting for more than 2 years. So the paint is not in the best shape but it still shines some. The interior is in good shape except for the bags. The driver side pillar has three holes in it from the apillar it used to have.
The car still needs some work as it still runs kind of sluggish at times. We cleaned out the fuel system,and got the fuel pressure to where it needs to be. The car does not over heat or anything like that, i need a daily driver and this car simply need more work than i can put into it at this point. I know its been a long time and im almost there but i want to move on to something else that i can drive to work and wont give me no problems.
Well im asking 5,500 dollars OBO
for the car. if you are interested please pm thanks
Here are all the mods off the back of my head, im sure im missing some minor things
teksid block bored .020
manley pistons (9.1 compression)
madmax rods
melling billet oil pump
powder coated valve covers and intake
stock b heads
stock 98 cobra crank
billet coolant resorvior
KNN drop in
IMRC Delete plates
03 cobra radiator
MAC LT heaeders
Dr gas xpipe
flowmaster mufflers
spec stage 3 clutch
04 cobra flywheel
mgw shifter (orange handle
fast shift knob
fordracing aluminum driveshaft
373 gears
front 4cyl springs
mm caster camber bolts
lakewood 90/10 struts
MM subframes
rear ford b springs
tokiko shocks
BBK lower and upper control arms
cobra r hood
black cobra rs
blacked out rear bumper letters
smoked headlights
red calipers
275/40/17 MT Drag radials
I will take 500 dollars off the final price if you dont want the hood, the headlights, and rear tires. Thanks guys
madmax rods
stock b heads
KNN drop in
IMRC Delete plates
03 cobra radiator
MAC LT heaeders
Dr gas xpipe
flowmaster mufflers
spec stage 3 clutch
04 cobra flywheel
fast shift knob
373 gears
front 4cyl springs
MM subframes
rear ford b springs
tokiko shocks
cobra r hood
black cobra rs
smoked headlights
red calipers
