Blacknite- I will send pics tonight! Love the shaved door handles and the polishing of the aluminum grill (I might have to do that).... I will hold judgment on the filler until the car is done! peace.....
Wow that is amazing!!!! IMO, I'm not to fond of the gas cap, but the rest is awesome! I'm getting rid of my GT emblems, antenna, rear emblem, trunk key hole, 3rd brake light, and decklid holes on my car! My only problem is that it is quite expensive...I really want to shave the door handles, but I've been quite skeptical of it, and the whole process on getting the door to open, and of course the price! Did you do all of this yourself?
Yes, ive done all the work myself. Its fairly easy if you can use a wire welder and its a good one. If not have some one do it. The doors and gas cap, i bought a door skin and cut a insert for it to match the body line. (less body work later)
As for getting the doors to open, its very simple. All you need is 2 door solenoid, mount them on the inside at the bottom of the door. Then run the wire rope to the latch that was conected to the door handle rod. Ground the solenoid and run a power wire to it from the keyless entry wire that unlocks the door when you push the remote. Power hits the solenoid and pull down on the door latch and unlocks the door. Then you have 2 choices, either install door poppers or just use you finger to open the door.
The way im doing it is to installing one of the truck area springs on the lower half of the door so it applies a small amount of pressure outwards and opens the door without having to worry about it popping open and hitting something beside it.
When i get back home from work to finish all the lose ends up ill take pics of the set up and some short vids of how it all works
That is awesome! I'm pretty excited to see these pics, and the vid of your doors! Approx how much money do you have invested in it? Of course, you've done the work, so that knocks out quite a bit...
Also, do you do body repair work as a profession? I'm still looking at a solid shop to do all my work, and I can't come down to anything.
Gas cap looks like a big puss-filled goiter.
just the look i was going for.....
it should be recessed by about 2 inches.
Any pics yet!!!!??!!
