car idles, but tach falls to Zero. Racing the engine brings the tach to life, but it falls to zero,
mach2race
My car seems to idle ok, but sometimes...the Tach, falls to zero RPM's, but the engine is still running. If i race the engine, the Tach jumps back up with the motor, but then falls back to zero, in an idle. I thought maybe I had a weak coil pack. I changed it with a screaming demon, new plugs and wires. That seemed to fix it for a couple of months, but now its doing it again ?
I would appreciate any help you guys can offer. I also replaced the clutch, because the original had 156,000 miles and i thought maybe the clutch was dragging, but car still idles (sometimes) between 300 to O RPM's
Thanks!
TB
Sounds like your tachometer has a bad stepper motor. It's not uncommon for the gauge stepper motors to go haywire on these cars especially in cold weather.
You can get a set of new x27 stepper motors from eBay. Removing and stripping down the gauge cluster is fairly straightforward. If you're handy with a soldering iron, you can do the job yourself. Otherwise pay a professional to do it.
