06silverbullet
so short story put the car on stands for a month, pulled the terminals as to not drain the battery, changed a rear brake caliper, did lca's and a phb brace.
go to fire it up this afternoon as i finally had a day off to work on it and it's running pretty "off"
checked for loose spark plugs all were tight
reflashed my tune didn't fix it.
it idles rough and almost sounds too low of an idle but its idling at 800ish
it has a huge lack of power/tq feels gutless
afr seems off it would idle tapped out on the lean side
sounds like it has an exhaust leak, but seems like if it was that bad it would literally have to be were a pipe was completely off
cel light isnt on
even in the throttle it sounds "choppy when its running like a pushrod motor sounds like. like it doesn't smooth out with increased throttle.
cel light isnt on
