whitepunisher
Haven't yet. Was going to grab one today...
new battery was just put in it.
around 11 when cranking and 12 just sitting there
but would the alternator not working cause it to not start/run?
Both cam sensors are the same, but cam sensors should not really be keeping the car from starting up. Who did your tune? I had issues with my tunes where the car would start up and have the idle flare up and come back down and it cut out. Got a supposed revised tune but it still did it.
I would be more worried about what caused the damaged on that sensor. Get it home and pull the valve covers. It could very well be the computer needs to go through the relearn because of the dead battery? Hope it is a simple deal bro.
This is incorrect.
The PCM needs to see the cam position sensor on the right bank to verify TDC of compression stroke or the engine will not start. Without a cam position sensor the PCM does not know if it is TDC of compression or exhaust stroke. Cam turns 1 revolution for every two revolutions of the crank.
Did you replace the cam position sensor or just try swapping left to right?
Lee
