GoFaster06
- Joined
- Jun 26, 2010
- Posts
- 225
- Reaction score
- 1
Just got car back from doing a compression & cylinder leak down test. Results are as follows: Compression: 1=204, 2=200, 3=196, 4=206, 5=190, 6=184, 7=200, 8=193 (all within 10%). Cylinder leak down test: 1=8%, 2=4%, 3=4%, 4=2%, 5=13%, 6=3%, 7=4%, 8=7%. Tests were done on cold engine, they had issues with getting correct adapter). Shop stated both test #'s would be higher on a hot engine.
Are these #'s within normal range or should I be concerned about anything. Shop said #5 (13%) has a piston ring seal leak. I had these tests done since I'm trying to pinpoint power loss. I've done all the smaller things, now looking at possible engine, supercharger problem.
