ChuckyRick
So as always the mod bug hit during this particularly harsh Atlantic Canadian winter and like most people i'm always looking for those little things that help clean up our engine bays. A couple of the things i have in mind are relocating the PS Reservoir just a little more towards the drivers side and make it a little more "hidden" and dong something about that god awful looking stock expansion tank. Now i am going with a WMS intake so it would be relocating to roughly where the stock airbox is anyways, however in my opinion the mounting position is a little too high and it just doesn't look like it should be there, But i guess they didn't have much of a choice or else it would no longer be the high point in the cooling system. So my question is this, yes obviously i could go with one of those remote mount catch can/expansion tank setups and probably mount it along the fender basically where the WMS kit relocates the stock expansion tank. But i'm wondering why not go old school? Get rid of the expansion tank setup completely and go with the simple radiator with filler neck and leave an inch or so air in the radiator for expansion. Now from what i understand as long as my new rad filled up to cold level had the same cooling capacity as the old rad+expansion tank there should be no adverse effects correct? Now if i do go this route it will be safe to assume that i would get a rad that would actually surpass the old set-up in cooling capacity, So really would this setup be on par if not slightly better than the stock setup and not to mention make the engine bay look alot cleaner? with about the only downside being that any excess coolant would end up on the pavement? Now someone please point out if i'm missing something here but to me it seems like a feasible option considering an aftermarket rad is only about 100$ more than one of those remote expansion tanks and would give you something that i can honestly say i don't think i've ever seen a modern mustang have. All feedback would be appreciated as i'm aware i'm definitely not an expert on cooling systems. but i think this would make for a super clean install if it would work.
cheers, Ricky
cheers, Ricky
