Just kidding with you.
gotcha, thanks for the explanationDrop is normal in a return system, it is somehow proportional to flow so it is expected to be higher than what I am used to see. See in the log the read fuel pressure, while you are idling it is around 46delta, at the end of the run is close to 36-37, that is what I was talking about. As long as table are set right (and I am absolutely sure they are) and enough injectors at that deltaP (as shown with DC and AFR) you are good.
yes tail pipe snifferAFR was measured in the tail, right?
How the heck are your IAT's that damn low!!!! 74 degrees at the end of the pulls is just crazy. I know you're running E85 but I thought that wouldn't show up in the IAT's since it's injected right into the heads and not picked up by the IAT sensor.
James, look at downstream data, GT500 has to air temp sensors, the one in 74 is in the MAF, the ACT2 is the downstream.
Gent
Attached are the logs of two dyno pulls made with the Shelby. Things look good to me in my very amateur review, any insights are appreciated as to how they look.
That's still amazing.
Sorry to clutter up your thread.
/END-HIJACK/
I'm not exactly an expert or anything but I noticed your fuel trims are off. The ecu is adding fuel in closed loop. Could be the maf xfer and it could be the blend of your local e85. Have you tested it lately and do you know what stoich the tune uses?
Apart from an unknown stoich value of current fuel used there are also differences induced with the cams and a disbalanced generated by bypass working.
All good James
/END-HIJACK/
Last 2x I checked it was 85-87% areaI'm not exactly an expert or anything but I noticed your fuel trims are off. The ecu is adding fuel in closed loop. Could be the maf xfer and it could be the blend of your local e85. Have you tested it lately and do you know what stoich the tune uses?t.
There were two fans blowing on the car.Just thought of another one that happened to me recently while on the dyno. A cooling fan was blowing some of it's air on the air filter with some of that air reaching the maf, causing the trims to get a little screwy.
