Detailing Questions-Answered
DKS
Wax on, Wax off.
VA/NC LINE
Glaze is basically a cheater product IMO. It primarily fills in scratches and adds oils to the finish to make it look good. I don't use Glaze, personally. I'd rather have the paint corrected and not just covered up. After you wash the car a time or two the swirls will come back and it will look bad again with a glaze
It's good for hiding stuff if you don't feel like polishing the swirls out. Most Glazes do not offer any protection and they are safe to use on fresh paint. I say most of them, because some companies call stuff "Glaze" that is not really glaze, just like with waxes and sealants.
Glaze is for sure not a necessary step for having a good finish.
ayabrego
Sprayed yaaa
Corpus Christi, Texas
Thanks dks happy I didn't buy any then. Just got done clay barring the car.
-Aaron
Vbshelbygt
Doug's Speed Shop
So I did my car over and the Black Fire WD is the shit. Have two coats and it looks great!
NastyStang113
Made in U.S.A.
Central Florida
DKS is right for the most part. I still use a glaze even with a 95-100% corrected finish. I feel like it adds some depth to the paint.
ayabrego
Sprayed yaaa
Hey dks i finally finish my car last night and when bring a light to it I still see quite a bit of micro scratches. Believe me the car looks great but is their anyway i can get those scratches out? I already used compound.
-Aaron
ayabrego
Sprayed yaaa
Yes by hand. I used alot if elbow grease. It is smooth and looks great i just wonder when using a polisher like the porter cable if it take out everything.
-Aaron
DKS
Wax on, Wax off.
VA/NC LINE
-Aaron
I'm sure it would. I can't imagine actually trying to polish a car by hand. I mean you can dig a grave with a spoon, but a shovel is better and a Back-hoe is ideal.
You're using a spoon my friend. A PC is a Shovel, a big shovel. And a rotary is a back-hoe, lol
Vbshelbygt
Doug's Speed Shop
All clean ready for the great weather this weekend!!!
Vbshelbygt
Doug's Speed Shop
Thanks dude it's looking much better thanks to you and all your info
DKS
Wax on, Wax off.
VA/NC LINE
Any advice on how to get swirl marks out of the car?
Yep, just buff them out using a real buffer and some M105 if they are bad and follow it up with some M205. If they aren't too bad you can use some swirl x or ultimate compound and follow it up with M205 if you really want it to finish out nicely. The key is to use a real buffer like a PC 7424 at minimum. It will take forever doing it by hand and even longer if you're trying to use a cheap wal-mart buffer, if you can even pull it off with one of those, which you probably can't. They don't make enough friction to even accomplish anything other than applying wax or sealant.
GRAYPNY
Rich
NorCal - Chico
I'll going to jump to the end here and ask what pad do i use on light scratches and swirls for the Porter Cable buffer?
