I am getting very close to starting my engine build and I need to make a decision. I have a set of ported big valve heads that I purchased used and had Modular Head Shop check out for me. They said that the springs on the heads were Pacaloy set up at 95# on the seat. I currently have a brand new set of Detroit Rocker cams for supercharged applications that I had planned to use but I am worried about VCT. Will VCT be able to reliably handle retarding cams with the heavy springs I have with the Detroit Rockers?
Would bigger (more lift) cams be easier for VCT to control with the heavy springs?
info on build:
JDM 302 forged stroker short block stock compression
ported big valve heads with Pacaloy springs
IW 10% OD balancer
oil pump with TSS billet gears
ID1000 injectors
Detroit Rocker SC cams (or???)
info on build:
IW 10% OD balancer
ID1000 injectors
