Flusher
- Joined
- Apr 26, 2016
- Posts
- 527
- Reaction score
- 250
Why would you be looking for a 9" rear end, I make well over 1000hp to the rear tires, ran the 8.8 with a tru-trac and 31 spline axles until just recently, I only changed to a spool to save weight. The 8.8 is a very good rear end with the correct parts.
Lighter. Runs cooler with an aluminum center section. Can have multiple center sections setup for street, strip, and road course. Center sections can be swapped in 20 minutes. With 4.56:1 and lower gears, there is always 3 teeth engagement as well as longer tooth engagement. The third pinion bearing adds substantial support.
