Autob
I've done all of these.....did you guys want to see the before and after of them? It was done with a rattle can but matching color of course. Turned out pretty nice. Here is a quick look at the most recent:
Also a note for performance white (probably applies to many other colors). When having the paint mixed make sure to get the exact amount the "recipe" calls for. So for example if the mix amount says xx oz of white xx oz of red xx oz of another color and so on which in the end equals a pint. Dont allow the paint mixer to pair it down to less than that. Otherwise you will have color variances and the PAINT WILL NOT MATCH. You may be only painting a small item but getting more matching paint (which you can save) is better than having a fender and the blend area a shade off.
Ive only had this ever happen with performance white. I got a quart it was off. thought ok well i got the cheaper line next time i will get the better line which is suppose to match better. Next time i got the higher line and it was horriably off. Got a whole pint mixed and it was better. There is alot more to this story but in the end the problem was with getting too small of an amount mixed and the red portion of tint in the white being just enough off.
