I am making sure I am hooking up the vacuum lines correct. Seeing I am running a manual boost controller I do not use the top port of the wastegate? Also then for my BOV I am using the vacuum block for my vacuum source which is fed from the bottom port on my intake manifold that I tapped as seen in the picture that I circled. I then also run my boost guage off the vacuum block as well.
