Renesis07
I posted about my first track day last month, which was by far the most fun I've ever had with any car I've owned. So that inspired me to look into some local events and I attended my first auto-X event yesterday (SCCA Solo)
So with that being said, please keep in mind I'm still 'green' with all this. Still learning the 'classes' of auto-x, learning about suspension, and most importantly working on my driver mod.
Yesterday I got placed in the 'Rear Drive Street Tire' class. I went there as an 'unknown' and that's where they placed me. So if this is wrong, feel free to let me know so I can be in the correct class next time.
Throughout the day I significantly improved my times, however I know there's a lot more to be had. My first run was 70 seconds, which is absolutely horrid. I had a DNF on that run anyways because I missed a cone, but at least that run got the 'first time running' nerves calmed down. I literally improved almost every run. My times on the next 5 runs were 65, 62, 60, 62, 60, then finished the day with my best run of 59.902 which was my goal (to break 60 seconds). Now, even though I was happy I was able to improve myself over 10 seconds in only 6 runs, my numbers were still far from where they should be. Seemed like the medium time in the class was right around 55 seconds (top of class were pulling off 53 second runs). So I was still around 5 seconds from even being competitive.
Something that came to light yesterday is that my car, when pushed to the limits, has horrid understeer. So bad to the point where I was having to apply throttle to essentially 'drift' myself straight again. The understeer was to the point where I would turn the wheel and the car would go straight and essentially 'hop' until I applied more throttle and compensated the understeer with an induced oversteer. On the easier corners and slalom cones my car felt balanced and easy to control but when the hairpin corners came about my car just didn't make the cut.
As I said earlier, I am new to the auto-x scene and really handling setups all together. I would really like to maximize what I currently have before dumping money into other modifications. I feel like I have more skills to learn and more in my current setup to utilize before determining what to do next. That's my thoughts at least, if I'm dead wrong feel free to correct me.
Here are my current suspension modifications:
Steeda Ultra Lite Springs
Koni Sports
Saleen Sway Bars
Steeda Tower Bars (Front & Rear)
BMR Adjustable Panhard Bar
When I installed the Konis, I essentially just set them to a softer setting that was even all around. Like I said, I don't know too much about suspension adjustments and wanted to see how the car performed before messing with it. Well now that I know I have understeer issues, I think it's time to start utilizing the konis. What do you guys think for correcting the issue?
Sorry if my post is really 'noobish', just looking for advice from the veterans on here and wanted to share my first auto-x experience. Thanks guys! Can't wait to get out there again, definitely addicted.
Oh, and of course a mandatory picture
Koni Sports
Saleen Sway Bars
