fore level 2 returnless system for 0f5-10
Bobby
turbo gt about to go fast
fore level 2 returnless system for 05-10
pm for pricing
S197-S 3V Level 2 Returnless System
750+ rwhp capable returnless fuel system with efficient hose routing. The feed line input to the front of the driver side rail and crosses over behind the motor.
INCLUDES
  • S197-S Fuel Hat
  • Dual GT Supercar Fuel Pumps
  • 3V Billet Fuel Rails
  • F10 Inline Fuel Filter
  • All fittings, hose, and hardware necessary to complete typical fuel line plumbing
    -Aeroquip -8 Kevlar/Nomex Fuel Line (one 15' sections for feed, and xover)
    -Qty 1, low profile 90 degree -8 AN to -8 o-ring fittings
    -Qty 2, -8 AN to -10 o-ring fittings
    -Qty 1, low profile 180 degree -8 o-ring/female to -8 o-ring/male fitting
    -Qty 2, 90 degree -8 hose ends
    -Qty 2, -8 o-ring plugs
    -Qty 3, -8 AN to -8 o-ring fittings
    -Qty 5, -8 hose straps with stainless mounting screws
    -Qty 4, -8 hose ends
    -Qty 2, 1/8 NPT plugs
    -6mL Loctite 567
ZmanM3
The Evil One
Jackson, NJ
Does it include all the lines from the fuel tank to the rails?
Bobby
yes you make the ends up so you can customize it like you want. it is a 100% complete kit. and if you would rather run a 2nd fpdm instead of just the one we can make that harness for you as well.
Bad Intention
New Orleans
I installed the Fore Innovation return fuel sys. on my 2011. Has worked great. Very well built and easy to install. I also have there wiring kit.
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Jeremy will be unavailable until Dec so contact Bobby or I for your needs.
