BruceH
BBB Big Bore Boss 322
I've been chasing a front cover oil leak since building this motor. It's built from a 2004 Mach 1 block 1L.
I bought the block used and it had been cleaned with a power tool prior to me buying it which has caused leak paths.
I spent the weekend taking everything off the front and sealing the front cover on with ultra grey rtv. Took it out for a 10 minute drive and had a clear path coming down the front cover from one bolt hole. Further investigation clearly shows it was weeping from under the bolt head or from the empty hole above. My next try at this will be a wet rtv bolt install with a cap seal over the bolt head and filling the empty hole with rtv.
That's the background. I'm wondering if this is a known problem with the 1L block and a 3L timing cover? Perhaps there is a small mismatch somewhere that's hard to find if you don't know what to look for?
