Agent Jones
Never got around to installing this on the mustang.
Retails for 379, will sell for 300 shipped.
or buy this and the A/F Wideband together for 420 shipped, Retail is 579
This is the one that will read all the information from your OBDII sensor so you dont have to run a whole bunch of gauges.
Available OBD II parameters
Throttle Position
Intake Pressure (MAP)
OBD Type
Fuel Level
RPM
Air Flow (MAF)
Oxygen Sensor Voltage1 (Bank 1)
Barometric Pressure
MPH
Short Term Fuel Trim (Bank 1)
Oxygen Sensor Voltage2 (Bank 1)
Catalytic Converter Temperature
Engine Load
Long Term Fuel Trim (Bank 1)
Oxygen Sensor Voltage1 (Bank 2)
ECU Voltage
Engine Timing
Short Term Fuel Trim (Bank 2)
Oxygen Sensor Voltage2 (Bank 2)
Absolute Engine Load
Air Intake Temperature
Long Term Fuel Trim (Bank 2)
Ambient Air Temperature
Water Temperature
Fuel Pressure
Fuel Pressure Relative
**Some of these parameters will be not available in all vehicles. Please check with your vehicle manufacturer if you have questions regarding what your specific vehicle offers.**
Intelligent Multi-Functional Display (iMFD)
Description:
The PLX MULTI-GAUGE is designed specifically to display a wide variety of automotive information far superior to that of a standard automotive gauge. The MULTI-GAUGE can display up to 4 different sensors of your choice simultaneously. Unlike other automotive displays on the market where the user has no choice but to view the data presented in one form PLX has designed the MULTI-GAUGE so that you can set and change your viewing preferences at any time. All styles have their unique advantages and you should not be limited to one option.
Eliminate the need for multiple gauges with the PLX MULTI-GAUGE. Run all PLX Sensor Modules and view up to 4 parameters at once on one crystal clear Organic LED display.
Features:
Universal OLED color display available in sizes 2 1/16" or 60mm.
iMFD Display Module
Customizable gauge styles, backgrounds & colors
Analog, Digital, Graph, 4 Parameter styles
Organic LED display
Set peak and hold points
Intelligent warning
Daisy chain up to 32 PLX Sensor Modules
Simple to install
http://www.plxdevices.com/multigauges.html
http://www.youtube.com/watch?v=957TTByL0Ls&feature=player_embedded
[/QUOTE]
Throttle Position
OBD Type
Fuel Level
RPM
Air Flow (MAF)
Barometric Pressure
MPH
Engine Load
ECU Voltage
Engine Timing
Water Temperature
Fuel Pressure
Description:
Features:
iMFD Display Module
Organic LED display
Intelligent warning
Simple to install
[/QUOTE]
