dangerzone
sparkplug
Im in the middle, well rather end of doing a gt500 swap into my fox and got a question on the gt500 pump assembly. 1st, i simply swapped the locking ring from thr gt500 tank to my fox tank and the pumps slide right in. The depth was spot on. Question, i plugged the pick up line for the pass saddle tank. This shouldnt effect any fuel flow or anything should it? I took the factory pick up line (plastic) and heated it up and crimped it flat with pliers. so it could draw no fuel. This whole contraction is only about 2 inches, and i installed it on the pump where the factory pick up tube for the pass side was?
